Oficina => Performance => Tópico começado por: teco em 31 de Outubro de 2012, 00:38
Título: T25 para TD04
Mensagem de: teco em 31 de Outubro de 2012, 00:38
Quero comentários e ajuda nalgumas traduções
NG900/9-3 Owners Wanting to Convert
New information for you guys specifically. I know some of you want to convert to the TD04 turbo replacing your T25, and after some research I have some confidence in what I say. I have the correct part numbers needed for your turbo lines!
Parts Needed
Turbo to Manifold Gasket - 91 13 937
Exhaust Manifold Gasket - 91 66 497
Oil In Banjos Smaller Size (x2) - 91 43 967
Washers Smaller (x6) - ?? ?? ???
Oil In Pipe TD04 - 91 79 458
Oil Return Pipe TD04 - 91 80 522
Oil Return Pipe Gasket - 91 07 582
Water In Pipe TD04 - 91 74 947
Water Out Pipe TD04 - 91 82 460
Washers Medium (x6) - ?? ?? ???
Older B234 9k Owners Wanting to Convert
There are some obvious differences in the lines versus the newer 9k lines. One being the Oil in pipe, its much much longer and is bolted to the back of the block versus the oil filter housing. Luckily, some older 9k b234 engines had the TD04 15G turbo, so its possible to convert. Everything looks the same except where the lines are placed. So I have reason to believe you can use any TD04 HL 15T turbo or 15G, BUT you need to get the proper lines listed below. This only applies to those with the B234 engine T25 turbo wanting to convert. Sorry B202 owners, this doesnt apply here.
Parts Needed
Exhaust Manifold Gasket - 75 18 996
Oil In Pipe TD04 - 91 38 769
Oil Return Pipe TD04 - 91 68 204
Water In Pipe TD04 - 91 38 785
Water Out Pipe TD04 - 91 37 928
Título: Re: T25 para TD04
Mensagem de: SMAP em 01 de Novembro de 2012, 09:26
Eu tinha um topico com isto tudo explicado no outro foum :(
Para ja traduzi isto para te dar uma ajuda, mas com tempo eu faço um topico mais detalhado.
NG900/9-3 motores B2x4x
Peças necessarias
Junta entre o colector de escape e o Turbo - 91 13 937
Junta entre a cabeça e o colector de escape - 91 66 497
Parafusos que apertam os tubos (x2) - 91 43 967
Anilhas pequenas para os parafusos (x6) - ?? ?? ???
Tubo de entrada de oleo TD04 - 91 79 458
Tubo de saida de oleo TD04 - 91 80 522
Junta do tubo de saida de oleo - 91 07 582
Tubo de entrada de agua TD04 - 91 74 947
Tubo de saida de agua TD04 - 91 82 460
Anilhas medias para os parafusos (x6) - ?? ?? ???
9000 de 1994 a 1998
Peças necessarias
Junta entre a cabeça e o colector de escape - 75 18 996
Tubo de entrada de oleo TD04 - 91 38 769
Tubo de saida de oleo TD04 - 91 68 204
Tubo de entrada de agua TD04 - 91 38 785
Tubo de saida de agua TD04 - 91 37 928
Mensagem de: teco em 01 de Novembro de 2012, 11:05
obrigado, é que assim quem queira comprar peças cá tb sabe o nome ;)
e como o outro forum morreu abhei que seria útil.
