Oficina => Motor / Escape / Admissão => Tópico começado por: SMAP em 04 de Janeiro de 2014, 20:54
Como alguns de voçês (eu incluido) gostam de andar a trocar os turbos ficam aqui as principais diferenças em termos de part numbers e em que motor podem usa-los.
Motores B2x4x (9000, NG900, 9-3 ate 1999 excepto o Viggen)
http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15437&Vehicle_ID=32222&check=ffd153711f7b2ef781d6b6948e29624a (http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15437&Vehicle_ID=32222&check=ffd153711f7b2ef781d6b6948e29624a)
Turbo Buildsheet
Turbo OE No: 49189-01600
Service Turbo no: 49S89-01600
Turbo Model: TD04HL-15G-6.0
Vehicle OE No: 913955
Fitted To Make: SAAB
Fitted To Model: 9000 2.3 AERO (1993)
Fitted To Engine: B234R
http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15438&Vehicle_ID=30765&check=d1cf01846dc911576f4aeeff5849bd23 (http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15438&Vehicle_ID=30765&check=d1cf01846dc911576f4aeeff5849bd23)
Turbo Buildsheet
Turbo OE No: 49189-01700
Service Turbo no: 49S89-01700
Turbo Model: TD04HL-15T-6.0
Vehicle OE No: 9149634
Fitted To Model: 9000 2.3 AERO (1994 a 1998)
Motores B2x5x (9-5 e 9-3 apartir do ano 2000 nos motores 2.0 e no Viggen)
http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15439&Vehicle_ID=3257&check=285740cf8e9b9c0a26fc3416e4350c38 (http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15439&Vehicle_ID=3257&check=285740cf8e9b9c0a26fc3416e4350c38)
Turbo Buildsheet
Turbo OE No: 49189-01800
Service Turbo no: 49S89-01800
Turbo Model: TD04HL-15T-5.0
Vehicle OE No: 9172180
Fitted To Model: 9-3 VIGGEN
Fitted To Engine: B235R
http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15439&Vehicle_ID=35988&check=285740cf8e9b9c0a26fc3416e4350c38 (http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15439&Vehicle_ID=35988&check=285740cf8e9b9c0a26fc3416e4350c38)
Turbo Buildsheet
Fitted To Model: 9-5 AERO
Motores B2x7x (9-3 SS)
http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15574&Vehicle_ID=36260&check=5ce5301aa030ff4b1b4486c802bc1c53 (http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15574&Vehicle_ID=36260&check=5ce5301aa030ff4b1b4486c802bc1c53)
Turbo Buildsheet
Turbo OE No: 49377-06501
Service Turbo no: 49T77-06501
Turbo Model: TD04L-14T-6.0
Vehicle OE No: 12788719
Fitted To Model: 9-3 AERO
Fitted To Engine: B207R
http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15577&Vehicle_ID=3281&check=a33731fc1e0760b92e7db4f190e0f3dd (http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15577&Vehicle_ID=3281&check=a33731fc1e0760b92e7db4f190e0f3dd)
Turbo Buildsheet
Turbo OE No: 49377-06600
Service Turbo no: 49T77-06600
Turbo Model: TD04L-11TK3-5.0
Vehicle OE No: 55557611
Fitted To Model: 9.3 2.0 (todos menos AERO)
Fitted To Engine: B207x (todos menos B207R)
Motores B284x (9-3 SS)
http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15617&Vehicle_ID=3303&check=2e3f10040d4e3cc8045e6780c74c9361 (http://www.melett.com/turbo-buildsheet-detail.php?BuildSheet_ID=15617&Vehicle_ID=3303&check=2e3f10040d4e3cc8045e6780c74c9361)
Turbo Buildsheet
Turbo OE No: 49389-01710
Service Turbo no: 49T89-01710
Turbo Model: TD04H-15TK3-12.5
Vehicle OE No: 55557012
Fitted To Engine: B284x
PS1: embora grande parte da informação tenha sido tirado do site da melett, corrigi alguma informação pois por exemplo no motor dos 9000 estava la 234FT em vez de B234R
PS2: esta informação diz respeito aos motores que vinham equipados com TD04 de origem, claro que podem usar os TD04 nos modelos que não vinham equipados com eles de origem desde que metam lá os TD04 correctos para o tipo de motor SAAB (B2x4x, B2x5x e B2x7x)
PS3: Os NG 9-5 (apartir de 2010) e os 9-4X (2011 e 2012) tambem usavam motores 2.8 V6 com TD04 mas para já não tenho a referencia dos mesmos, embora ache que deva ser igual a dos motores B284x que equipavam os 9-3 SS
Todas as duvidas retiradas O0
Obrigado Smap :)
Tinha essa informação aqui de lado para postar há uma carrada de tempo...
Sempre que precisava disto tinha que ir procurar, por isso reuni para consulta :P
Só te falta aí um...
o Td04 14T só é usado no Aero B207R, nos restantes é utilizado o TD04 11T.
Possivelmente também devíamos de colocar a diferença entre os TD04 - 15T a nível de colector de escape para não haver confusão dos 9000 para os 9-3/9-5
Obrigado pela partilha :D
Adicionado
