SAABs - Modelos => Saab 9000 => Tópico começado por: Guest em 26 de Outubro de 2012, 13:49
Título: Especificações de Material de Manutenção Saab 9000
Mensagem de: Guest em 26 de Outubro de 2012, 13:49
Muitos já sabemos, mas é sempre útil ter isto á mão:
Fluid type/specification (UK specification 9000)
Engine oil:
Grade: Saab Turbo Engine Oil or an oil which meets the requirements of API SG and CCMC G4 or G5.
Viscosity: 10W/30, 10W/40, 5W/30 or 5W/40
If these grades are not available, oil of viscosity 15W/40 may be used, but not in winter.
If 5W grade oil is used it must be of synthetic or semi-synthetic type.
Coolant:   Saab approved anti-freeze (Haynes recommends an ethylene glycol-based antifreeze)
Manual transmission oil:   Engine oil to API Service SF/CC or SF/CD, SAE 10W/30 or 10W/40.
Synthetic oil must not be used.
Automatic transmission fluid:   Dexron 2 ATF
Brake and clutch fluid:   Hydraulic fluid to DOT 4
Power steering fluid:   Saab Power Steering Fluid 1890, Texaco Power Steering Fluid 4634 (only available from Texaco in 25 litre containers), GM power steering fluid (Texaco TL 4634)
Haynes recommends "Saab or GM power steering fluid". I have also been told that any fluid from a GM dealer will do.
Capacities
Engine oil (including filter):
B202: 4.0 litres
B204: 4.7 litres
B234: (to 1993) 4.3 litres
B234 (1994 on) 4.7 litres
B308: 4.5 litres
Difference between MAX and MIN dipstick marks: 1.0 litre approx.
Coolant:   4-cylinder engines: 9.0 litres
6-cylinder engines: 8.0 litres
Manual transmission oil:   To 1993: 2.5 litres
1994 on: 1.8 litres
(incl. torque converter and oil cooler):   7.2 to 8.4 litres
(service change):   3.0 to 4.0 litres
Brake and clutch fluid:   Unspecified. 2 litres is more than sufficient for a complete fluid change.
Power steering fluid:   0.75 litre
Spark plugs
Note that the Saab Direct Ignition (DI) system is very sensitive to the type of plug, due to the fact that it uses the plug as a sensor to measure a number of engine parameters and was developed exclusively with the specified NGK spark plugs. While some people have reported some success with the latest type of NGK Platinum plugs, the best advice is to stick to the recommended NGK plugs only. Bosch Platinum plugs have been tried by a number of people, but don't seem to work well for long before they give problems. If you feel like experimenting, remember that you must use resistor-type plugs with DI. Non-resistive plugs will damage the DI cassette, which is not cheap to replace.
The non-DI system (i.e. with a distributor) is much less fussy and a number of equivalents have been found to work well.
Engine   Plug type   Gap
2.0i (non-DI)   NGK BCP5ES   0.6-0.7mm (0.024"-0.028")
2.0i (DI)   NGK BCPR6ES   1.0mm +0.1/-0.2 (0.040" +0.004/-0.008)
2.0 turbo (non-DI)   NGK BCP7ES   0.6-0.7mm (0.024"-0.028")
2.0 turbo (DI)   NGK BCPR7ES   1.0mm +0.1/-0.2 (0.040" +0.004/-0.008)
2.3i (DI)   NGK BCPR6ES   1.0mm +0.1/-0.2 (0.040" +0.004/-0.008)
2.3 turbo (DI)   NGK BCPR7ES   1.0mm +0.1/-0.2 (0.040" +0.004/-0.008)
3.0 V6 (normal driving)   Bosch FR8 LDC   0.8mm (0.031")
3.0 V6 (hard driving)   Bosch FR7 LDC   0.8mm (0.031")
Fonte: www.saab9000.com (http://www.saab9000.com)
Título: Re: Especificações de Material de Manutenção SAAB 9000
Mensagem de: teco em 26 de Outubro de 2012, 20:26
BOM POST!
bahh, fica na mesma apesar do outro post
e apesar dos mitos há quem se dé bem com BCPR7EIX-11 nos SAAB 9000 2.3 t16 MAS é duvidoso que sirvam se for para um com cheiro a atum
Mensagem de: Guest em 26 de Outubro de 2012, 22:49
Lolol... La vem o atum. Bebe pistachos e minis que isso passa :)
Mensagem de: TesZero em 07 de Novembro de 2012, 12:30
Eu já o disse várias vezes e volto a repetir...
não vejo mal nenhum em usar velas em iridium desde que sejam a mesma referência do que as pedidas...
Desde que tenham o R para leitura do knock, especialmente...
Deixem-me acabar estas a ver se não vão lá estar umas em iridium!!!
Kamuma... traduz lá isso, senão vou ter mais um trabalho :D
para depois ser mais facil organizar a informação solta pelo forum.
Quanto ao óleo, é de salientar que o que se recomendava ha 10 e 20 anos não é o que existe agora... portanto... óleo 100% sintético SEMPRE!!!!
Parabéns pela info :D
Mensagem de: castelar em 07 de Novembro de 2012, 13:42
Bom Post sim senhor.
Aguardo o mesmo tipo de post no 9-5. :D ;D
