How to fix Light control relay in:
- 900NG 1994-
- 9000 1988-
- 9-3 1998-2002
- 9-5 1998-2011
1.
2.
3.
4.
5.
6.
7.
i saw a lot of cars with that problem...
and it is a very expensive relay... (200€ +/- 800 zt - something like that... in PORTUGAL)
i just didnt understud what you made, you just re-weld the contacts?
Regards -
Regards
Yes, this relay is expensive but repair is so simple
We only have to solder(re-weld) those pins
Very nice zeli... Thanks for that. Hope to be usefull to someone who needs.
Best regards -
very good tip
Thanks -
Em virtude de se ter perdido as fotos por não estarem alojadas no nosso fórum encontrei estas que reponho
Abrir o relé
Verificar as soldas
E podem seguir abaixo as descrições de cada ligação, parece que os números estão gravados
Pin 56A - common for high beams
Pin 56AR - lead for right-side high beam
Pin 56AL - lead for left-side high beam
Pin 56B - common for low beams
Pin 56BR - lead for left-side low beam
Pin 56BL - lead for right-side low beam -
Parabéns ao autor do tópico
Também estou com problemas neste relay.
Mas não querendo fazer off topic, vou criar novo tópico para ver a opinião do pessoal.
