41 Visitantes, 0 Utilizadores
[DIY] How to fix Light control relay
Iniciado por zeli, 16 de Novembro de 2012, 10:57
zeli
How to fix Light control relay in:
  • 900NG 1994-
  • 9000 1988-
  • 9-3 1998-2002
  • 9-5 1998-2011
SAAB partNo. : 4109070
1.
2.
3.
4.
5.
6.
7.
  • SAAB 9-3 99' B204L
i saw a lot of cars with that problem...
and it is a very expensive relay... (200€ +/- 800 zt - something like that... in PORTUGAL)
i just didnt understud what you made, you just re-weld the contacts?
Regards
zeli
Regards
Yes, this relay is expensive but repair is so simple :)
We only have to solder(re-weld) those pins :)
Very nice zeli... Thanks for that. Hope to be usefull to someone who needs.  O0
Best regards
Em virtude de se ter perdido as fotos por não estarem alojadas no nosso fórum encontrei estas que reponho
Abrir o relé
Verificar as soldas
The selected media item is not currently available.The selected media item is not currently available.
E podem seguir abaixo as descrições de cada ligação, parece que os números estão gravados
Pin 56A - common for high beams
Pin 56AR - lead for right-side high beam
Pin 56AL - lead for left-side high beam
Pin 56B - common for low beams
Pin 56BR - lead for left-side low beam
Pin 56BL - lead for right-side low beam
JSequeira
#6
Parabéns ao autor do tópico  O0
Também estou com problemas neste relay.
Mas não querendo fazer off topic, vou criar novo tópico para ver a opinião do pessoal.
